- al cope
Dashcam power
Chaps - also asked on the "old" forum
for those with a dashcam fitted to your D5 where are you picking up 12v power? - I will be refitting my Blackvue and this has the cigarette type power plug on the end. I can only see one socket in the front for this and that would mean having loose cables around the center console. I dont mind chopping this plug off and connecting into a 12v ignition switched feed - if so from where?
- solihull
- al cope
OK Cheers - so just ordered one of those piggyback power feeds. Once I have it I will go in search of the 12v switched fuse number mentioned in that thread.
thanks
- chaos_theory
Hoping to use OBDC plug so it can be used in parking mode and avoid warranty issues from hardwiring
Andrew
- al cope
actual turned out much easier - i used the 12v socket in the upper glove box. OK you can see the wire but only a few inches of it and its not loose and dangling about
- Russell
I used a piggy back fuse to the fuse box behind the glove box. You can get a female cigarette lighter socket and hide that behind there as weel fed from piggy back fuse.
