    Regarding the MY19, how sure is it that these faults are 100% rectified? Still a bit early to tell?
    MY19 most likely has the N222 patch applied when it comes out of the factory. Unless they changed the exhaust system and put an injector on the DPF to clean it instead of dumping in extra fuel in the engine?
  • Chalkys HSE
    The 2019 is the SDV6 which has gone back to two turbo's as it was in the D4
    With a close coupled DPF so wont have any issues of it not getting hot enough to regen, causing oil dilution (be it real or imagined by the computers)
    Easy to tell, its 306ps not 258ps
    ‘With a close coupled DPF‘
    => that’s what I want to be sure of
    One that's near the engine (where its supposed to be) so easily gets to several hundred degrees
    Close coupled like this?
    3 - DPF
    5 - Catalytic converter
    Ron, from which engine is the picture?
    Not the td6...
    Well, according to the workshop manual it is. Here's the top end of the page too, published in 2016 so I would think this applies to all TDV6 engines, MY17+18.
    Although it only mentions 2018 where the document reference is. Maybe they changed the exhaust design for 2018?
    So, thesis setup should get hot enough for a decent regen, ‘avoiding’ the oil dilution and keeping the service interval more or less on track. But we know that even for the MY18 this is not really the case.
    Am I missing something?
    But maybe this is why the MY18 could have the "early service warning" fixed with a software patch and MY17 can't?
    Could be, although this N222v3 patch still has to convince me that it works. Not impressed with it so far, but only a few 100km done to compare, so still hoping for the best!
  • Brooks1sr
    2018 Discovery TDV6 HSE Corris Grey
    Hi mine had n222 software update done in October oil service reset to 16000 miles I've done 2300 miles and says 11500 to next oil service so I reckon I'm going to get half the mileage for oil service about 8000 miles got it booked in at dealers to confirm then it could be getting rejected mine is a my18
    So not really any different to a 2017, as mine did 6000 and said a service was 1000 miles away, dealer did it whilst sorting out all other stuff they hadn't done before i got it in september.
    So only safe purchase is a 2019 model with SD6 engine then
    I assume in the 350 miles since its not tried a regen as the miles have only dropped by 300 so far
