  • eelpout
    i just noticed yesterday that in addition to the Bluetooth not working, the Voice command switch on the steering wheel does nothing. Going into the Voice command screen and pressing Tutorial does nothing either. Sad
    though not all is lost because when using Android Auto via a phone, pressing the Voice button on the wheel does bring up the Google voice assistant. Smile
    I think my compass doesn't work either BTW.
    I have a message into my (US) dealer to see if they know anything about the 19A release.
    For what it's worth, I had a Jaguar F-Pace for a week in snowy Minnesota this past week (first night we had it, it snowed 9"!). Was shocked at how well this thing did in snow with stock all-season tires. The low traction launch worked great when I parked in a pile of snow. One has to go to the "slippery/snow" mode to get any early engagement of the front wheels in snow, but it performed quite well then. Really, the only thing it's missing is adjutable-height air suspension. Odd that the I-Pace has it and the F-Pace doesn't.
    The Jag wasn't free of ICTP issues either: the middle LCD display in the instrument cluster refused to dim and the seat heater, when used, was always set to high, regardless of the three level setting. Neutral
    And what's with "premium" level model not having proximity door locks?!? I always had to get the damn key fob out to unlock it. Mr. Green
  • Hedgehog
    Germany
    2018 Discovery Sd4 (240) HSE Lux Aruba
    @paulp:
    It depends where the have looked and made the screenshot. With the old software versions it shows that there is no software update available and the system is at the latest version on your Disco´s screen.I think it is because this versions are not able for update through internet / wifi connection.
    @eelpout:
    Seems to be almost like mine Confused
    Are you sure that it is not working or it is just not talking to you? Mine is working when you press the button and wait a while the command list shows up on the screen just showing "127" instead of the commands you can choose. You can give a spoken command and I your are lucky the system does it. It is just dumb!
    The compass I have to check.
    How about the TV? Can you search or switch channels?
    Hedgehog
    Disco 4 Nara bronze gone but not forgotten - Disco 5 Luxury Aruba / Light Oyster
  • Browser
    19A..
    19A
    2019 HSE LUX
  • eelpout
    Hedgehog wrote:
    @eelpout:
    yeah, Voice is not working. pressing the wheel button and waiting does nada (it use to work just fine before the update). and like I said in my other post, if you go directly to the Voice commands screen, the (touch) buttons there do nothing either.
    I'm in the US. don't believe we have the TV feature enabled because.... reasons. Wink
    Re: 19A..
    Browser wrote:
    19A
    Seems this pic is a left hand drive LR with 19A ?
  • winger
    Au point! Wink
    Wink
  • Browser
    Software update 19A now released - notes
    Here you go...update if you dare !!!
    InControl Touch Pro 19A has arrived: Version S19A_19.07.2-312706 Release Notes
    Saturday, March 2nd, 2019 by Michael
    The latest release notes for InControl Touch Pro (Duo) 19A, enjoy
    IMC (INFOTAINMENT MASTER CONTROLLER) – SOFTWARE VERSION: S19A_19.07.2-312706, PART NUMBER: K8A2-19C204-BB (G2369115) INCONTROL© TOUCH PRO 19A
    Release Date: 2019-02-27
    New features included in this release
    DRIVER ASSISTANCE FEATURES
    Improved warning messages for Reverse Traffic Detection.
    CLIMATE
    It is now possible to adjust the second row temperature controls (where fitted) from the front upper screen.
    NAVIGATION
    Improved screen for manually adding personal charging stations.
    10" TS only: It is now possible to select numbers and letters on the same screen when entering destination in Navigation system.
    ELECTRIC VEHICLE SCREENS (ELECTRIC VEHICLES ONLY)
    Improvements to the auto-add charge station and associated features.
    Touchscreen view improved with updated preferred charging station settings.
    Simplified range map display.
    BLUETOOTH® AUDIO
    It is now possible to change Bluetooth® device from the BT Audio screen and in media source selection list screen.
    INCONTROL TOUCH PRO DUO TOUCHSCREEN
    The lower screen will now dim by the same amount as the upper screen when in stealth mode.
    TERRAIN RESPONSE SCREEN
    Revised terrain response imagery.
    WI-FI HOTSPOT (F-TYPE 19MY ONLY)
    This update introduces hotspot support for F-Types.
    ISSUES FIXED IN THIS RELEASE
    ACTIVE EXHAUST BUTTON (VELAR SVA-DYNAMIC ONLY)
    Active Exhaust Button now available on lower touchscreen.
    BLUETOOTH®
    Bluetooth® phone call connection improvements.
    Bluetooth® Media will now reconnect automatically after unplugging iPhone™ from the front portable media interface panel.
    General Bluetooth® usability improvements.
    CLIMATE
    When auto is selected, changing the distribution mode will cancel auto and the blower speed in the rotary dial will now change to its previous value.
    NAVIGATION
    When searching for specific Points of Interest (POI) using speech, it is no longer necessary to stipulate a search area.
    Navigation start-up speed improvements.
    Hybrid Charging Station filtering is now possible on PHEV vehicles.
    Display will now work in low power mode.
    Electric Vehicle (EV) button is now available on the Touchscreen (PHEV vehicles only).
    Creep Mode not correctly displaying in the Touchscreen.
    Estimated time to charge is no longer displayed unless a charging cable is connected to the vehicle.
    Regenerative braking state can now be selected on-screen at start up.
    RADIO
    General stability improvements – MW Band.
    Tuner screen – various bug fixes.
    REVERSE TRAFFIC DETECTION
    ‘Reverse Traffic Detection not available’ message will no longer be displayed on touchscreen when system is active.
    SMARTPHONE PACK FEATURES
    Fixed Smartphone feature failure to launch at startup.
    (China only) improved robustness when switching from iPhone™ to Baidu session.
    (InControl Touch Duo only) CarPlay screen is not aligned with the center of the Touchscreen when launched while source selection screen displayed.
    Loss of audio mid-cycle when listening to Spotify with Apple CarPlay.
    Improved Android Auto connection strategy.
    SYSTEM
    STARTUP
    General start-up improvements.
    GOODBYE SCREEN
    Goodbye screen will no longer appear at the wrong time when the engine is switched off.
    MULTIMEDIA PLAYBACK
    General stability improvements.
    SPEECH DATABASE UPDATES
    Update of Speech Database using service screen – robustness improvements.
    SVR LOGO (SVR VEHICLES ONLY)
    SVR Logo no longer changes size during start-up.
    REAR SEAT ENTERTAINMENT
    General robustness improvements.
    The rear screens no longer default to on at start up.
    KNOWN ISSUES IN THIS RELEASE
    REAR VIEW CAMERA JUDDER
    The camera image is not displaying as smoothly as it should be, this is currently under investigation and should be fixed in the next full software release.
    2019 HSE LUX
  • roverhaul
    Hi all, not trying to be a jerk but if you're going to just copy and paste from my website and actually leave my name in the post, maybe just give some attribution back to my site? Even the picture showing the 19A LHD ICTP screen was submitted to my Twitter.
    Thanks,
    Michael
    ovalnews.com
  • PaulP
    Spain
    Hedgehog wrote:
    @paulp:
    Do you mean on the ICTP screen? Or on the dealer's Pathfinder system?
    They showed me a "print screen" of their Pathfinder which they also confirmed was fully updated. But...in no moment could I see anything related to the software numbers we usually discuss here (2017A, 2018C etc etc). It looked like they were maybe trying to update one of the modules of the ICTP system and not the main user-facing software itself.
    As nobody else has mentioned that the new versions are not available in their country, I guess that it is not market-specific (ACP/AA pack maybe is?).
    If this is true, then does anyone with a good knowledge of Pathfinder know what I have to explain to them to get them to "find" the update and apply it?
    They're great guys, but the D5 is still a bit new to them and I just need to point them in the right direction.
    Thanks,
    Paul
  • Browser
    Thanks,
    Michael
    ovalnews.com
    Michael, no offence intended - This from Oval News, I thought it had it in there with your name ... : Smile
    2019 HSE LUX
  • harrythespider
    I DON'T dare Laughing
  • winger
    Seems to be working just fine. Smoother and faster.
    Thanks,
    Michael
    ovalnews.com
    Touchy
    +1 Thumbs Up
