  • Rstebbings
    Update once you have configured and retested please - hoping this fixes your issue
    MY20 D5 HSE Lux - Carpathian Grey
    MY17 RRS Dynamic - Corris Grey
  • pdes
    CraigP, Good idea.
    Series 1, 1953, 86"
    Just thinking as you do. Maybe the supposed shortage of tow bars is more to do with the towing issue. Just sayin!
    A few thoughts before we all panic too much.
    Is the caravan loaded the same as when you towed it with the D4, reason i ask is that if we run our Swift elegance 645 lightly loaded it is a bit bouncy, it always runs better loaded and with a high nose weight.
    What are your Tyre pressures like in the rear tyres
    What size wheels do you have fitted and what load rating are the tyres?
  • Jacko
    pdes wrote:
    Yep, Tow Assist is included. Haven't set it up yet though.
    Hi pdes,
    Maybe it will behave itself once the car knows about the van. ie If you set it up can you let us know if you still have issues. Maybe car is trying to second guess things which is what your experiencing. Just saying. but I woudn't have thought for everything you pop on the back of the car you need to *Setup*
    Hi Lee I think the tow assist is more about reversing wrt the setting up procedure. That's what I gleaned from the link I posted earlier. Yes the brakes are applied if it feels a swaying motion but I don't think you have to set up for that. However I have been wrong before.
  • Jacko
    Hi Craigp,
    We may have chatted before in the other forum Smile
    Some of the videos i have seen show putting in dimensions etc of the trailer. as i type this thinking your prob right, used for reversing.... but then again.. a simple test to find out...
  • B16 KJR
    As the Alko ATC system is constantly 'grabbing' the brakes of the trailer slightly during driving, that's what makes me wonder if the cars TSA is detecting those actions and interpreting them as instability, thereby activating the ATC, which combined with the TSA is making the caravan feel and behave strangely. The only way to find out for sure, is to disconnect the ATC for the journey home.
  • hatjoepeg1
    its not the lane assist thing causing issues is it?
    I switch mine off on narrow roads/lanes as it can be quite drastic when there is limited room on the road.
    Works fine on the motorway though so long as I indicate?
    1986 90
    2017 D5
    Mine is off permanently here in Devon, it is far too irritating on our local roads..
  • PeterW
    No experience of caravan towing
    Lane assistance I like, have learned not to "fight" it relaxed hands & it's excellent.
    Try fighting it you & car overreacts.
    Peter
    HSE 3.0 V6 Diesel Corris Grey
  • fisherman
    My D4 is as good a tow car as you can buy but if the tyres are not inflated to their top pressure for pulling my van it swings all over the place. Same thing applies to the van, it needs to be spot on to be wobble free.
  • B16 KJR
    I have arranged an extended test drive on the 6th April, so I will be hitching my caravan onto the D5 and taking it for a good long run. My caravan doesn't have the Alko ATC system fitted, so I will soon find out if there are any inherent instability issues with the car itself !
    I will post my thoughts after the 6th Thumbs Up
    If you increase the tyre pressures then make sure you tell the on-board computer!!
  • B16 KJR
    Is that because of the TPM system ?
