  • 33Lurcher
    When I go in settings and select car play then LR Discovery then Customise it lists the Apps that are available (they show up on the cars screen when connected via cable) .
    Below this list is a section called More Apps (which is empty)
    I thought the downloaded Waze would perhaps be there to add to the list above it .
    2021 D250 S Eiger Grey HSW Privacy Hi/Low Ratio
  • Equilibrium
    Ah gotcha. Haven’t been in that menu for years.
    For me, waze is in the main list, not more apps. More apps is not clickable.
    Other apps that I have downloaded since buying the car, such as Deezer, have appeared in the list too. I don’t recall doing anything to get them there.
  • 33Lurcher
    Found a away to get the downloaded apps into the list , power down phone then power up and the new apps are in the list in the phone Thumbs Up
  • 33Lurcher
    Just noticed that when I plug the iPhone in Apple Car Play no longer shows on screen , tried the dash & cubby box connection , no luck .
    Any suggestions?
    Not sure if this is the same issue, but at times I need to unlock the iPhone screen before CarPlay will show.
  • 33Lurcher
    Thanks for reply , tried that still no luck .
