      - 33Lurcher
      When I go in settings and select car play then LR Discovery then Customise it lists the Apps that are available (they show up on the cars screen when connected via cable) .
Below this list is a section called More Apps (which is empty)
I thought the downloaded Waze would perhaps be there to add to the list above it .
2021 D250 S Eiger Grey HSW Privacy Hi/Low Ratio
      - Equilibrium
      Ah gotcha. Haven’t been in that menu for years.
For me, waze is in the main list, not more apps. More apps is not clickable.
Other apps that I have downloaded since buying the car, such as Deezer, have appeared in the list too. I don’t recall doing anything to get them there.
      - 33Lurcher
      Found a away to get the downloaded apps into the list , power down phone then power up and the new apps are in the list in the phone
      - 33Lurcher
      Just noticed that when I plug the iPhone in Apple Car Play no longer shows on screen , tried the dash & cubby box connection , no luck .
Any suggestions?
      - IndusD4
      Not sure if this is the same issue, but at times I need to unlock the iPhone screen before CarPlay will show.
      - 33Lurcher
      Thanks for reply , tried that still no luck .
