- MAC OSX
Trailer detection system.
It seems that later D5s can detect presence of trailer fitted with LED lights.
Is this due to a SOFTWARE or HARDWARE upgrade?
If SOFTWARE can a dealer impliment this upgrade?
If HARDWARE can the detector unit be changed for the later version?
In the latter case perhaps someone in the know could advise the unit part number for the later version.
- MalithS
I am pretty sure nothing on the hardware or software has changed to make the car detect lower threshold LEDs. The owners manual detection limits have been the same since launch.
- IndusD4
Re: Trailer detection system.
Yes you are correct, MY 18 and up are correctly detecting trailers with LED lights. The trailer indicator light works, gearbox holds on to gears longer and auto access mode doesn't work with the trailer attached.
This is despite what the manual says. Seems the manual hasn't caught up with model changes.
Someone here had a software upgrade done however that didn't fix it. So we're unsure what was changed, just know MY18 and up works. And there's someone with a MY17 that works as well.
- MAC OSX
Towing Module
Some people report that shunt resistors will overcome this problem. I have fitted shunt resistors and the system works. Others report system works without shunt resistors. Has there been an update in the spec of the "Towing Module"?
D5 HSE Lux 2019
- Brooksie69
I know this is an old subject but I am having the same problem as others and after searching on here came across this thread.
I have a 2023 D300 SE MHEV just had a Detachable towbar fitted with vehicle specific 13 pin electrics.
The fitter fitted a control module to allow LED trailer lights.
Everything works except the little green trailer light on the dash when indicating all lights on lighting board work except rear fog on car doesn't go off when lighting board on.
I have coded the towbar via the IID, also had some help from Pat at GAP but still unable to get the indication when a trailer attached.
Would the LED mod box prevent the indication or could it be the car must detect a caravan or trailer on the Towbar?
The reverse sensors deactivate and the PDC sensors are inactive.
Any help or info would be great, if anyone has done this to their vehicle what coding did you use and did you use a module to help with LED trailer lights.
Thanks.
