  • PatGAPInnov
    2019 Discovery Si6 HSE Santorini Black
    Send me a PM, its a G2 thus will need updating to a G3 unit...
  • Duckers
    IID BT update from Gap
    From Disco 4 site
    GAP Diagnostic–update announcement 2022-10-20 Report post
    ---2017+ LRs Announcement---
    Hello Everyone
    Hope you are all well.
    Patrick here from GAP Diagnostic. For those who do not know us, we have been providing diagnostic tool for LR enthusiasts for a few years now Wink
    We first want to thank everyone who have been supporting us all these years. Its been quite a fun journey!
    Finally, after a long development cycle, we are proud to announce that the beta testing phase for the following 2017+ vehicles is well under way:
    -L663 Defender (the demand for this one was something else!)
    -L462 Discovery
    -L550 Discovery Sport
    -L405 Range Rover
    -L551 Range Rover Evoque
    -L494 Range Rover Sport
    -L460 Range Rover
    -L461 Range Rover Sport
    -L560 Range Rover Velar
    The IIDTool BT (Gen 3) and IIDTool Pro (Gen 3) are suitable for these platforms. Earlier Gen 2 units cannot be used due to hardware limitations but we do offer an exchange program from G2 to G3 units.
    The aforementioned tools are now capable of the following functions including a few specific examples:
    -Faults
    -Height Adjust (change vehicle height)*
    -Height Control
    -Calibration*
    CHCM--Suspension, Guided Calibration, Manual Calibration
    -Service Test:
    IPC-Instrument Pack, Service Interval Reset, DPF Regen*
    GWM--Gateway Module, Battery replacement
    CHCM--Suspension, Set normal/Tight Tolerance Mode, Test Valve
    ABS--Parking Brake Pad Replacement, Release / Exit Service Position
    RFA--Remote Function Actuator, Key Coding, Check Number of Keys*
    -Live Values, complete list
    -Car Configuration File editing, complete list*
    -ECU Flash (fast lane)*
    -ECU Info
    *VIN Locked
    We will of course add functions as development progresses.
    Anyone interested in participating in the beta phase are welcomed to contact us via our website contact form;
    https://www.gap-diagnostic.com/
    And for those already in the loop, by email, PM or reply to this post!
    GAP Diagnostic team http://www.gap-diagnostic.com/
  • Trevor
    How do you identify whether the iid tool is a gen2 or gen3?
  • terryall
    If you have registered it with GAP they will tell you straight away whether you need to upgrade and my guess is that you do.
  • terryall
    Just an update on this but I have asked Pat at GAP Diagnostics if, and when, the IID Tool Gen 3 will be available to buy direct in the UK. I would sooner do that then get a new one posted from Canada.
  • Popsdosh
    The G3 has been available in the UK for some time JGS 4x4 have them as do BAS and island 4x4 they are even available second hand on the usual sites and very easily spotted as they have a blue G3 on the label. Personally bought one recently for 300 on ebay.
  • terryall
    Thanks for the information. I thinkI will buy one and sell the D3 Gen 2 I have now to help fund it.
    Over 400 quid? Seems expensive. If you just want to read and reset codes are there cheaper options?
  • hughmartin
    2022 Discovery Si6 HSE Lux Carpathian Grey
    Seat Folding calibration
    I used to have a IID tool when I had a D4 and sold it when I sold the car. Having now come back to LR in the form of a 2024 D5, I am considering buying a new IID tool but need convincing of its functionality. For instance, I have twice had problems with a 2nd row seat freezing when folded. Will the IID tool reset a seat fault and recalibrate the seat?
  • BadgerWaz
    Afternoon boys and girls, I have a GAP IID 4, and have used this on another LR we have, and with great success altering codes in the ccf. I've enabled so many features that LR hadn't, and I'd like to do the same with our Disco.
    Are there any Disco 5 owners who have activated the Dynamic setting/ACC etc. etc. using their IID?
    If there is a sticky on the site I'd be grateful if anyone has a link. Using known settings saves heaps of time in trial-and-error over weeks of driving, so I thought it was worth asking the question.
    (I have used the search function prior to registering but the posts came back without the actual info. I'm looking for so I've posted on this old relevant thread.)
    Thanks in advance, Badger. Thumbs Up
    A small tweak with the IID tool to have the auto stop/start disabled by default...
    Start the engine and select the auto stop/start switch to off...
    Fire up the IID tool and go into Car config.
    Select all then wait for the complete CCF list to load, search for MultiCAN-566 MHLastUserMode in the search box (or do it the hard way and scroll down till you find it) and change the option in Last User Memory Mode from disabled to Enabled and upload the new setting.
    This doesn't permanently disable the auto stop/start, it only changes the operation from being enabled by default on each engine start to remembering what it was last set to. If you want to enable or disable the auto stop/start at any time...just use the button as normal.
    This CCF tweak I've tested on my 2017 3.0L TD6 ...works fine Mr. Green
