    Battery monitoring
    Hi guys just thought I’d share the battery monitor system I’ve just fitted and to be honest for the price and work to fit it’s a nice little gadget
    The bolt to secure to the positive was a 8mm x8mm long bolt
    13mm socket for the 8mm bolt
    10mm socket to undo the neutral earth point
    I really must get around to fitting mine. I bought one months ago Rolling Eyes
    Nice pics Dazz Thumbs Up
    Thanks mole , my battery doesn’t look the best though
    Putting it on charge tonight
    Yeah we’ve discussed this gadget before here: Linky
    It’s the same one as I have had on a few earlier Discoveries. Works well in conjunction with a Ctek mod that I think is on the same thread. 😃
    That's another thing I've still to get around to, your excellent CTEK front grille mod. I should have done it before winter set in of course Rolling Eyes
    Can you drop a link of that mod please
    Narpy's CTEK grille mod linky
    There's a front grille pic on the following page...
    Very smart
    I realised this morning I left my gap tool in over night so definitely need to charge it now
    Also fitted my ctek tail similar to narpys
    Good effort.
    It’s super handy to be able to monitor your battery condition and even handier to be able to plug in your Ctek with the car nose in. On the odd occasion I back onto the driveway, I also have a 13pin charging adaptor for the tow electrics.😉
    I’ve got the deployable tow bar so the plug socket tucks itself up into the underside
    I’m guessing it’s not advised to go straight to the battery in the rear then
    Yeah you can do, that won’t be a problem but I go in via the tow socket so the car can remain locked.
    I do have a Ctek connector on the battery but it needs fitting to the panel, it’s one of those bulkhead connectors. The charging cable will run and the tailgate will close with the cable compressing the tailgate seal, in fact, it works just fine.👍🏻
    👌🏻 thanks
    Just abit of feed back with the monitor with some screen shots
    That’s 15 days view
    7 day view
