  • phillh
    Do I need a new battery?
    Good evening,
    I have owned my 2017 D5 3.0 HSE since October 25 and really love it.
    My only query is if I leave the car for a week or more, I get the 'Low Battery - Start Engine' come up on the dash. Is this a common thing or should I renew the battery?
    I tend to user the car only for longer runs as I understand they don't like being used on short journeys in town as it can clog up the emissions systems. Otherwise I would use it a lot more.
    Many thanks
    PhillH
    Hi Phill.
    I get the same if I don't use the car for a few days. Usually a run around the island for an hour sorts it out for a few days at least...we only have 25 miles of single track roads around the island so unfortunately most of my journeys are short stop/start. I usually stick a bottle of Wynn's DPF cleaning fluid in the tank when I top up with diesel, it helps stop the ash build up in the DPF a bit.
    Besides that, short journeys or not...turn the auto/stop start off during those trips through the town, your engine and battery will thank you for it...just as the car will with being used instead of being parked up. Wink
    Once every few weeks, I head over on the ferry to Mainland and blast the car around the decent A roads over there for a while to give it a decent run out at higher revs until I get the local ferry back home.
    Like yours, mine is a 2017 HSE and I suspect the battery is now 9 years old and a bit tired...I'll be looking to replace it at some point with a decent Bosch 95AH one, the OE battery is 80AH so the Bosch (or similar AGM brand) will be better suited to the limitations of living on a small rock in the north sea.
    I usually buy from here
  • phillh
    Thanks Mole,
    Will keep an eye on it. Thanks for the tip about Tanya batteries btw.
    My 2017 still did that even after replacing the battery.
    I have a habit of leaving the car unlocked at home (in the rear of our property). Do that a couple of nights and the battery will be asking to be recharged.
    The funny thing is…it’s stopped doing it so much recently.
    Since having software updates reloaded at main dealer I have noticed several changes to the vehicle. One is that the auto stop/start seems to kick in more regularly…even after shortish journeys. It’s as if the battery is getting a better charge now.
    Just my observation.
  • 747_JK
    On my fourth battery (three replacements) in my MY23.5. I find they are bloomin' useless, but all mine have been replaced under LR Assist, so it's at their cost, not mine, But still!
    My BlackVue dashcam probably doesn't help, but it was a pro install and the settings are set to switch the thing off a the most sensitive of battery levels, so as not to risk anything. That said, after 10 days on the drive last summer whilst away on hols, the car was effectively totally dead.
    I just kind of live with it... the other day, when cleaning/loading the car prior to returning from hols in Scotland, with the doors & boot open for a good couple of hours, I ended up just switching the ignition on for the last 35/40 mins, just to ensure no "low battery" warnings when wanting to leave swiftly to catch the ferry next morning...
  • phillh
    Thanks for your replies. I will monitor it and fit a little voltage meter in my accessory port to make sure the alternator is charging correctly.
    Re: Do I need a new battery?
    phillh wrote:
    Good evening,
    Many thanks
    PhillH
    I only just this spring replaced my factory battery on my 2017 HSE Td6. I was astonished that it lasted this long. Its degradation was fairly graceful, however, in the last few weeks of its life I had to jump it, until one day it simply could not be resuscitated. I did occasionally get the Low Battery - Start Engine notification in the months before that.
    I replaced the battery myself (in a ski lodge parking lot, where it ultimately died) - you'll need a few tools but hopefully nothing you don't have at home. The retaining bracket was a bit of a bear to get off as the battery cables were kind of packed in there and very stiff in the cold.
    Now I keep it on a battery tender at home if it's going to sit for a while, even though the battery is brand new and a highly rated premium unit.
  • Penuwchian
    Changed the battery on my 2017 2.0lt yesterday. Only 25k miles on it but the same battery from new.
    Mole's Tanya batteries came good- great price and next day delivery
