  • swansty
    2022 Discovery Td6 HSE Carpathian Grey
    Russell wrote:
    I did my sons with the ditch finishers in place on the car
    I presume there wasn’t anything underneath them then to hit with the drill? How did you know where to drill and how did you cut out the bits?
  • swansty
    In case anyone else wants to try this…. I bought aftermarket rails from LRparts.net. Seem to be good quality. They come with a sticker template pack to put on the car trims to mark the cut outs. I didn’t remove the trims from the car and cut them in-situ. I used a dremel and just squared the ends of the cut out rather than curving them as per template and it worked fine. Just note - the front trim is aluminium I think and it took about 6 cutting wheels per side. I made my cut outs a bit smaller than the template and found it difficult to get the metal brackets into place while they were attached to the rail so I just removed them and then bolted down through. I preferred to leave more material on the trims.
    Silly Q time
    Tell me dear Oracles… Can you position the cross bars anywhere along the roof rails or only at fixed points?
    Not sure which roof box to but yet.
    Many thanks
  • swansty
    I believe on the OEM LR ones, the cross bar position is fixed but on aftermarket it is variable.
    Not my experience I’m afraid.
    I bought after market rails and bars. The bar foot that attaches to the rail has a pip that needs to locate in a hole on the inside of the rail. On the ones I have, there are only two location holes, one for the aft bar and one for the forward bar.
    Some users have ground off the pip so they can locate the bars where they wish, I decided to add extra holes to the rails and locate in them. I figured the pip was there for a reason and didn’t wish to push my luck.😳
    This thread, especially the video, may be useful. https://disco5.co.uk/forum/thread4288.html
    Good luck with it, it’s a proper pain in the ‘arris.😳
    Thank you. Thumbs Up
