  • swansty
    2022 Discovery Td6 HSE Carpathian Grey
    Russell wrote:
    I did my sons with the ditch finishers in place on the car
    I presume there wasn’t anything underneath them then to hit with the drill? How did you know where to drill and how did you cut out the bits?
  • swansty
    In case anyone else wants to try this…. I bought aftermarket rails from LRparts.net. Seem to be good quality. They come with a sticker template pack to put on the car trims to mark the cut outs. I didn’t remove the trims from the car and cut them in-situ. I used a dremel and just squared the ends of the cut out rather than curving them as per template and it worked fine. Just note - the front trim is aluminium I think and it took about 6 cutting wheels per side. I made my cut outs a bit smaller than the template and found it difficult to get the metal brackets into place while they were attached to the rail so I just removed them and then bolted down through. I preferred to leave more material on the trims.
