- sufun
I don't have discounts on Data only plan.
No problem
- PeterW
Am I correct in thinking this sim has no expiry date so can be brought now ?
Edit: talking about the sim on jimbg 's link
Peter
HSE 3.0 V6 Diesel Corris Grey
- PeterW
Just read "my question" on Amazon seller states no expiry date. I will take a chance and purchase.
My reason is so I can get my dealer to set up everything on hand over
Peter
- PeterW
Scrumps
Peter
- Scrumps
Scrumps
- PeterW
Apologies
Was thanking jimbg
Peter
Peter,
Did you order one of these, if so then I presume you activate it and that is the start of the 12 month period?
Jim
- PeterW
Jimbg
Haven't got round to it just yet, but yes that's what I think.
Peter
- PeterW
From Amazon reviews
Question:
Is this limited to 1 gig of data a month...are can you use as much of the 12 gig as you like in one month thanks..
Answer:
"No. The 12 gig lasts for 12 months or 12 gig whichever comes first. i.e. you could use the whole lot in the first month if you wanted to. I have since bought the 24 gig which again is for 24 gig or 24 months whichever comes first. Price when I bought it was excellent value.
Mrs. Jb Morris answered on 21 Nov. 2016"
Peter
- neilk
The one I bought went into an unlocked TP Link MIFI device but it seems activation starts the 12 month clock, and I am guessing activation is the first time it connects to their network.
I added a top up and that showed expiry after a month (but it did queue until the initial allocation was used then the month starts). I have a second one I will put in the car when it comes.
You register then with the my three portal and it shows the data balance and the expiry time, but they need to be active first as it requires an SMS delivered authentication code to the SIM number. I presume the car has a mechanism for displaying SMS messages to the inbuilt SIM.
- PeterW
Amazon Reviews
Would this be possible from car ?
"You can check your balance (even without registering) by going to
http://mobile.three.co.uk, then select My3 then Account Balance & add-ons.
You have to check it on your mobile device that the sim is in and it has to be using the sim (i.e. not on WIFI).
Hope that helps.
By MR G. on 20 January 2017"
Peter
- neilk
I will try it with the one I have tomorrow (mifi) as I suspect you can check from a data connection from that SIM, so you could check without authentication when attached to the wifi hotspot in the car which is the equivalent of checking on the device itself. The alternative would be to register the SIM in a phone and then transfer it. Any unlocked phone with a micro sim or larger should work.
