- mordred1973
to defrost the car and warm it enough to be meaningful, from a usual UK winter of about 0 to 2 degress in the morning it would need to run for about 20 mins, takes ages at idle to get much heat out of a diesel engine. my neighbours and otherhalf would not be happy if I did that every morning, whilst its quite a refined diesel, it still has a clatter in the silence of 6am. I wouldnt even consider doing it.
- mordred1973
they won't care, our Diesels are much more refined than the majority on caravan sites....
- JackNorris
From the brochure
Remote Premium 1 2 app provides upgraded information on your vehicle and enables you to
interact with it remotely. Compatible with most smartphones, Android™ Wear or the Apple
Watch®, this service includes:
– Remote Lock/Unlock – Lock or unlock your doors remotely with the click of a button.
– Remote Climate – Prepare your Land Rover in advance by pre-heating or pre-cooling the
cabin, so that you and your passengers are comfortable from the moment you step inside.
– Beep/Flash – This feature turns on your Land Rover’s hazard lights, dipped headlights and
sounds an audible alert to help you locate your vehicle in a crowded car park.
– Journey Tracking – This opt-in feature can automatically record your journey history
including your route and mileage statistics. This information can be exported by email
to use for expense reporting.
– Vehicles Status Check – Check current fuel level and range, and status of door and window
position and locks. See the last parked location of the vehicle and find your way back to it
with on-foot directions.
1 Optional on S when Navigation Pro is specified. Standard on all other trim levels.
2 Remote Premium contains subscription services that can be extended after the initial term advised by your Land Rover Retailer.
InControl features, options and their availability remain market dependent – check with your Land Rover Retailer for local market availability and full terms. Information and images displayed in relation to the InControl
technology, including screens or sequences, are subject to software updates, version control and other system/ visual changes depending on options selected. Mobile network connectivity cannot be guaranteed in all
locations. InControl Apps and
- Simon S
So is it just climate that is active if the vehicle is started in this way or do things like heated screen and washer jets / seats automatically start heating themselves if the temperature is appropriately cold?
I'd value the heated seats, screen and washer jets above the climate control on a cold day
Simon S
- RDR
So the FBH has been dropped from standard on uk spec SDV6 engines? Have they done something different to help warm up? it’s been standard on those engines as far back as I can remember.
MY23 Range Rover PHEV
- IndusD4
What we need is reverse cycle aircon in the car, so you can use it to heat the car interior up independent from the engine warming up - like with cooling you'd get warm air flowing in a few minutes after starting.
- Simon S
Bit of a post hijack but does the remote start function also turn the light on if it’s dark?? (For example early morning would a remote start potentially shine the headlights in a neighbours house for 10 mins?)
Simon S
- IndusD4
No it doesn't turn on headlights, the only thing that lights up is the dashboard and the buttons on the centre console.
- Simon S
Thank you!
Trying to figure out parking arrangements prior to delivery...... is it just me that is preparing more than for the arrival of a baby!?!?!
Simon S
- IndusD4
Sounds perfectly normal to me,
- Russell
RDR wrote:
Does remote start via the app actually start the engine or just start the FBH like having the separate remote fob?
It starts the engine as there is no FBH on moet D5's it is available as an option.
But beware the remote start is illegal in many places in the UK.
