      - maxmax
      Dashcam power from mirror
      Has anyone got any useful thoughts about using the power supply from the rear view mirror for a dashcam?
      - bammmy
      I wired mine under the head lining down the front passenger A post to the cigarette lighter socket  in the glove box , absolutely no problem. It also meant I didn’t have to tap into the vehicle wiring 👍
      - Russell
      Under headlining down passenger A pillar trim and into fuse box behind the glove box, there you can choose permanent live or ignition live
      - maffffster
      does the A pillar panel come off easily ?
      - bammmy
      No need to remove, it tooks behind the trim👍👍👍
      - milesg
      Fusebox under glovebox, fuse 51 is a switched live.  Earth can be on the metal subframe. Pop off dash end cap, run the cable up the side of the  A pillar under the black trim then under headlining at the front to the cam.  Pop on the end of the dash, close the glove box,  A 10 min job max.
Remember if you are getting piggyback fuses, they are the Micro 2 fuses.
HSE Lux in Silver / Black
      - simonh
      Can you get into the glove box by popping off the dash end cap ?
Served by the excellent Shukers Land Rover of Ludlow - 10 Land Rover’s and  20 years of amazing customer service.
      - milesg
      Yes!   Just pull it off, you can't damage then it just pops back on.
      - simonh
      Thanks !
