  • maxmax
    Dashcam power from mirror
    Has anyone got any useful thoughts about using the power supply from the rear view mirror for a dashcam?
  • bammmy
    I wired mine under the head lining down the front passenger A post to the cigarette lighter socket in the glove box , absolutely no problem. It also meant I didn’t have to tap into the vehicle wiring 👍
    Under headlining down passenger A pillar trim and into fuse box behind the glove box, there you can choose permanent live or ignition live
  • maffffster
    2017 Discovery TDV6 HSE Loire Blue
    does the A pillar panel come off easily ?
  • bammmy
    No need to remove, it tooks behind the trim👍👍👍
  • milesg
    Fusebox under glovebox, fuse 51 is a switched live. Earth can be on the metal subframe. Pop off dash end cap, run the cable up the side of the A pillar under the black trim then under headlining at the front to the cam. Pop on the end of the dash, close the glove box, A 10 min job max.
    Remember if you are getting piggyback fuses, they are the Micro 2 fuses.
    HSE Lux in Silver / Black
    Can you get into the glove box by popping off the dash end cap ?
  • milesg
    Yes! Just pull it off, you can't damage then it just pops back on.
    Thanks !
