  • PeterW
    Hi Stuart, can I borrow your pic with the boxes to send to my dealers please?
    Peter
    HSE 3.0 V6 Diesel Corris Grey
  • Martin
    Site Admin and Owner
    I followed a D5 last week and that also only had the 3 LEDs on the outer cluster each side.
    I thought it was a awful lighting setup for such a big car Shocked
    06 D3 SE / 15 D90 XS SW / 88 90 Td5 / 68 BMW 2000 TI
  • PeterW
    Yes.
    Hopefully a software problem & easily fixed Surprised
    Peter
  • PeterW
    A still picture from Landrover promotional video showing brake lights. To aid explanation to dealer/ Tech guys.
    Peter
  • winger
    Worth pointing out to dealers that the Centre High Mounted Stop Lamp is a standard feature, listed in the configuration.
    I wonder if this is actually some snafu linked to implementation of the tow electrics, where it is thinking that the electrics are connected, when they are not - some of the rear lights should not operate when trailer electrics are plugged in.
  • stuart_f
    This forum must be filled the most polite people on the internet! Of course you can Peter, no need to ask.
    No news from the dealer yet but I have just managed to do more miles in the Range Rover I was loaned that I have in my own car. Not looking forward to filling it with fuel later Sad
  • winger
    B3 shows the correct operation of the stop lamp for the UK market on high line vehicles. The high mounted stop lamp should also illuminate.
  • Martin
    So microscopic brake lights is correct? Wow
    Winger, can I ask where you got the pics and info from?
    Jim
  • winger
    There is a socking great high level light at the top of the tailgate. Is the complaint that that is not coming on, or just that the side cluster stop lamp is so small?
    The picture came from the Workshop Manual.
    I think it that the side cluster is so small.
  • winger
    Well software isn't going to fix that!
    I think the view is that the boot segment should illuminate?
  • winger
    Might be a North American thing. I'll have to check and will post the diagram that explains what each light segment does too.
  • winger
    North American stop light operation is different, using multiple segments, However, this also acts as the indicator light too.
    So, section 4 should be lit on HSE and HSE Lux vehicles in the UK, as rear sidelight,
