- Slug
Sounds to be revving although not??
Hi All
Bit of a random one but my D5 (69 plate) sounds to be revving more than usual, although the rev counter reads fine.
Really quite noticeable at around 45-55mph.
Even my wife and son have noticed when they have driven it recently.
No idea what it might be, apart from perhaps a slight hole in the exhaust perhaps but I'm clutching at straws.
Only other thing is could it be related to having the "charging system fault detected" warning being on!!!
Slug
- Slug
Noise sorted.
Turned out to be a failed near side wheel bearing.
Alternator replaced at same time. Hopefully sorting out charge fault issues.
Thankfully both under warranty
- Mole HD
Good result in the end Slug. Thanks for following the post up with a resolution...may well help someone with a similar issue.
