  • Flatcoat
    2019 Discovery SDV6 HSE Lux Namib Orange
    Headlight Shut Lines
    Post washing the car this evening I noticed (for the first time) that my Headlights are not flush with the front bumper on the nearside and not flush with the wing on the offside....!!!
    Nearside:
    Offside:
    These are the only bits that are not flush and not the same on both sides.....!!!
    Anybody else have this...????
  • J77
    Never checked, I'm planning on washing mine tomorrow so will have a look.
  • J77
    Looks like mines the same
    And mine
    Off side rear fog light/reflector in the bumper doesn't sit completley flush
  • J77
    My rears don't sit flush either.
    Must be an Orange thing Laughing
  • Flatcoat
    Whilst at my local Land Rover Approved Bodyshop (to get pre-delivery scratches repaired......another story.....no saga) I asked about the headlight shut-lines.
    Apparently this can be sorted quiet easily under Warranty...!!! Very Happy
    The Approved Bodyshop put a claim in for me with Land Rover UK and will re-book my car in for the front bumper to be removed and the headlight/wing to be adjusted so all becomes flush....awesome.
    A case of trial and error with bumper on/off and headlight repositioning but all doable.
    Good luck with others Thumbs Up
    Trial and error leads to scratches and other damage, I don't think the head light flush fit is that major to risk all that work/damage
  • J77
    I checked mine over when I washed it, it only seems slightly out on the photo I posted the rest look flush.
    I'm not too concern about it at the moment, your car does look a lot worse than mine.
    You would think all these checks would be carried out before the car left the factory.?? Must be costing LR a packet to get issues like these rectified. Not to mention the inconvenience caused to the customer.
    Bumper removal is a pet hate. Broken plastic lugs/clips and missing grommets. Bumpers never the same and never seems to sit flush like before removal and feels alot more looser ie more play and not as rigid like beforehand. Not to mention scratched paintwork from boilersuit zips etc Sad
  • winger
    SSM issued for this (VIN restricted)
    Reference
    SSM73332
    Models
    Discovery / L462
    Title
    L462 All New Discovery Head Lamp Poor Profile
    Category
    Body
    Last modified
    16-May-2017 00:00:00
    Symptom
    108000 Ext. Trim/Accessories
    L462 Poor headlamp profile.pdf
    Content
     Issue:
    Land Rover Discovery (L462) prior to the vin of LR008316, Customers or Retailers may report that the Headlamp Profile to the fender (Wing) or the Headlamp to Grille / Bumper profile is incorrect – see attached file for examples
    Cause:
    Concerns within the build process
    Action:
    Should a customer or retailer report that the profile of the Headlamp to the Grille / Bumper is incorrect then the Technician is requested to first loosen the 3  Headlamp fixings as shown in the attached file and then gentle push inwards on the headlamp until flush or within the standard of 2mm  + or – 1.7mm. If this fails to align the profile then please replace the affected headlamp mounting bracket
    Part Numbers
    LR086096 –Right Hand Bracket, Headlamp Mounting
    LR086097 – Left Hand Bracket, Headlamp Mounting
    Should a customer or retailer report the Headlamp profile to the Fender / Wing  then the Technician is requested to replace the affected Bumper Mounting Bracket
    Part Numbers
    LR104987 – Right Hand Bracket, Bumper Mounting
    LR104988 - Left Hand Bracket, Bumper Mounting
  • J77
    I'm in VIN range HA, so I assume my car is affected. I'll need to have a look over it.
  • Martin
    Site Admin and Owner
    HA is the year and factory code (2017MY + Solihull).
    LR tech bulletins use a (non obvious) combination of the vehicle model ID (LR = D5, LA = D3/4, etc) and the last 6 numbers of the VIN (sequential build number).
    So check your last 6 numbers rather than any letters.
    06 D3 SE / 15 D90 XS SW / 88 90 Td5 / 68 BMW 2000 TI
  • J77
    👍🏻 I did wonder, looking back at past VIN numbers never seen an LR.
    Numerically my car isn't included, mines 009 range.
  • winger
    Embarassed
    Sort of took a bit too much for granted it seems!
    If you VIN is lower than/less than/not more than 008316 (last six digits), take note.
    Otherwise naff off.
  • Teemo
    Mine is 14xxx and the profile is pretty good. Flush along the wing, maybe protruding by 1 mm at the grill
