Post washing the car this evening I noticed (for the first time) that my Headlights are not flush with the front bumper on the nearside and not flush with the wing on the offside....!!!
Nearside:
Offside:
These are the only bits that are not flush and not the same on both sides.....!!!
And mine
Off side rear fog light/reflector in the bumper doesn't sit completley flush
Whilst at my local Land Rover Approved Bodyshop (to get pre-delivery scratches repaired......another story.....no saga) I asked about the headlight shut-lines.
Apparently this can be sorted quiet easily under Warranty...!!!
The Approved Bodyshop put a claim in for me with Land Rover UK and will re-book my car in for the front bumper to be removed and the headlight/wing to be adjusted so all becomes flush....awesome.
A case of trial and error with bumper on/off and headlight repositioning but all doable.
Trial and error leads to scratches and other damage, I don't think the head light flush fit is that major to risk all that work/damage
Good luck with others
You would think all these checks would be carried out before the car left the factory.?? Must be costing LR a packet to get issues like these rectified. Not to mention the inconvenience caused to the customer.
Bumper removal is a pet hate. Broken plastic lugs/clips and missing grommets. Bumpers never the same and never seems to sit flush like before removal and feels alot more looser ie more play and not as rigid like beforehand. Not to mention scratched paintwork from boilersuit zips etc
Reference
SSM73332
Models
Discovery / L462
Title
L462 All New Discovery Head Lamp Poor Profile
Category
Body
Last modified
16-May-2017 00:00:00
Symptom
108000 Ext. Trim/Accessories
L462 Poor headlamp profile.pdf
Content
Issue:
Land Rover Discovery (L462) prior to the vin of LR008316, Customers or Retailers may report that the Headlamp Profile to the fender (Wing) or the Headlamp to Grille / Bumper profile is incorrect – see attached file for examples
Cause:
Concerns within the build process
Action:
Should a customer or retailer report that the profile of the Headlamp to the Grille / Bumper is incorrect then the Technician is requested to first loosen the 3 Headlamp fixings as shown in the attached file and then gentle push inwards on the headlamp until flush or within the standard of 2mm + or – 1.7mm. If this fails to align the profile then please replace the affected headlamp mounting bracket
Part Numbers
LR086096 –Right Hand Bracket, Headlamp Mounting
LR086097 – Left Hand Bracket, Headlamp Mounting
Should a customer or retailer report the Headlamp profile to the Fender / Wing then the Technician is requested to replace the affected Bumper Mounting Bracket
Part Numbers
LR104987 – Right Hand Bracket, Bumper Mounting
LR104988 - Left Hand Bracket, Bumper Mounting
HA is the year and factory code (2017MY + Solihull).
LR tech bulletins use a (non obvious) combination of the vehicle model ID (LR = D5, LA = D3/4, etc) and the last 6 numbers of the VIN (sequential build number).
So check your last 6 numbers rather than any letters.
06 D3 SE / 15 D90 XS SW / 88 90 Td5 / 68 BMW 2000 TI
