- J77
I’ll need to update the maps on my Velar and see if that fixes the lost voice command.
pdes wrote:
simonh wrote:
Have you updated to the latest map? Apparently Nav voice control won’t work until you do.
I upgraded the maps again this morning and the version was just one digit higher! Anyway, it seems to have done he trick. I gave the voice control a very quick test and it worked!
Did not work on my car, I will update the Voice control thread with progress
- mcunnin
found something that's not working in the new update . The seat folding has a bug it will only let you fold of unfold all the seats from the screen. you can select the seat you want to fold and it dose not change just says "fold all". however if you go in to the settings and change the clash avoidance to on then you can fold them individually. Took it to the dealer and showed them its going in again for the 3rd time. not just for that but since the service they have not fixed all the issues and I am giving it to them again to try and fix them.
2017 HSE Lux 3.0L Santorini Black
- simonh
Here’s a new one on me.
My D5 now does a beep (like the start of the park sensor sound) whenever I press the rear wash wipe
Anyone else notice this or is this unique ?
- J77
Updated the maps on the Velar but still no voice, or text readout so trip to the dealer...... again!
The Incontrol system on my D5 SE was more advanced than the touch pro, in the fact it worked without fault.
you’ve to laugh or you would cry.
- simonh
Mine is still randomly dropping power to the media ports (as thus the media player connection) and not recognising iphones when plugged in. Just had the media port panel changed as we thought it was a hardware issue. Now it seems like is ICTP seemingly not happy with interrogating what's plugged in and dropping the connection.
- eelpout
I brought my '17 Disco HSE Lux in yesterday for a yearly check. I asked for "all the software updates." I saw on the invoice that some engine, CPU stuff was updated, but I noticed the InControl interface looked the same when I got home, i.e. no new "seat icon", voice nav, texting etc. I assume this means mine wasn't updated.
Do I need to ask for InControl to be updated
specifically, even though the updates have been out for so long?? That's a bit annoying, unless some dealers are holding back if there are issues with them.
- simonh
Mines had latest ICTP but I don’t have the text function at all. Also forgets I don’t want keyboards clicks even though it’s set to off. Depending on where and when the keyboard appears I get clicks or no clicks.
- mcunnin
so simonh do you have a deplorable tow bar? If so after the update dose it forget its deployed once you turn the ignition off? mine started to do that and you can then only put it back from the boot switch. also if you dont mind would you check and see if you turn off the anti-collision in the seat folding settings screen can you select and fold the seats individually?
- simonh
Hi, no deplorable (
) tow bar on mine. I can fold the 60/40 split seats independently yes. I had the seat module updated though as my drivers seat wasn't always returning to its previous position when using the row three access buttons on the row two seats.
- mcunnin
so when you say module update was that hardware or software?
- simonh
A software update. Also they re-calibrated the seats (never knew seats needed calibrating !).
- eelpout
I asked my dealer why they don't automatically do InControl updates and they said plainly (after I realized they had not updated my MY17) that the updates tend to introduce more
new problems than fix things.
They'll do them of course if one insists, but they don't recommend it. Guess I'll watch this thread and wait to see if the software stabilizes.
- Russell
Well my car is back in for the software issues since the update and so far they have no idea how to fix or cure the problems and are waiting on LR technical
It is also in for a bang/cracking noise from underneath which they can hear but cannot trace
Oh well will see what happens
- Dirty Trucker
Is the noise at low speed? And from the rear end?
