rogersmj
Lets hope the Phase 4 update doesn't expect you to have the 2 screens as per the Velar! If i'm right in saying, the second screen is used for the climate side!
MY18 Corris Grey HSE Lux TDV6
jimbg
jimbg
Right, I have just "found" the climate physical button next to the left Auto button.
That takes you into the Climate menu, have to admit I have never noticed it before, I had to RTFM!!
simonh
Do you not have a SYNC button on the dash as well ?
jimbg
No.........Do you? Am I missing something?
Do I need to RTFM again?
simonh
Yes I do
Don’t you ?
Mines a 17MY HSE like yours so you should have one.
jimbg
That button says Auto on my car, but I have 4 zone A/C.
Arslanoff
I have a 3 zone AC and both sides AUTO
jimbg
But what do those buttons do exactly?
IndusD4
I thought the auto button sorts out where the airflow needs to be directed itself to get the car to the desired temperature.
IndusD4
As well as adjusting the fan speed.
jimbg
I presume one button must be for the front and one for the rear?
IndusD4
That would make sense.
simonh
Ah Jim, mine is the standard HSE climate control. The Sync just syncs the passenger temp to the drivers setting.
neilk
With the 4 zone you can switch off “Auto” for each zone. From memory with the standard Auto was for everyone, even if the temperatures were different. Just moved from HSE to HSE Lux.
